Is it possible to modify a firmware default?
Hi guys.
I would like to know if is it possible to modifiy a firmware file. To change the default image of a background cisco ip phones 7941 and 7942.
Jaime Valencia
No, files are signed and you cannot modify them at all.
No way to change the background that comes embedded in the FW.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
