Is it possible to reset 1000 phones in CUCM
GI Alex
Hello all,
I wondered if you know a way to reset 1000 phones at a time in CUCM?
Here is the scenario:
cluster with 15000 phones.
The goal is to disable ringer option for users only to 8851 type phones by saving this change in Common Phone Profile. Without applying the configuration!
Then to push the change down to the phones: by performing a reset on these phones (type 8851) from Bulk management, but in portions (let's say 1000 at a time).
Is this achievable ? Do you know how ?
Kind regards,
Alex
As your a Cisco employee you should use your internal options to ask this type of questions.
Response Signature
GI Alex
Possible approach: Export the list with phones in csv file and add description Batch 1, Batch 2 then save the file and upload it.
Filter the phones using description parameter in Bulk Mngmt to reset in portions of smaller quantity.
Kind regards,
Alex
