Issue the incoming call to IVR with cucm centralized
Hary_CsC
Haii,
I have a problem with the incoming call, so when called 02126507525 from 27301 (IVR) the number could not be reached.
*cucm centralized
Configuration VG as follows:
voice service voip
mode border-element license capacity 30
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
supplementary-service media-renegotiate
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through none
sip
registrar server expires max 600 min 60
early-offer forced
midcall-signaling passthru
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 5
no call preserve
voice translation-rule 2
rule 1 /02126507525/ /27301/
voice translation-profile INCOMING-SIP-TELKOM
translate called 2
dial-peer voice 2001 voip
description ** via SIP Telkom **
translation-profile incoming INCOMING-SIP-TELKOM
session protocol sipv2
session target ipv4:x.x.x.x
incoming called-number ^02126507525$
voice-class codec 1
voice-class sip transport switch udp tcp
voice-class sip early-offer forced
dtmf-relay rtp-nte
fax-relay ecm disable
fax-relay sg3-to-g3
fax nsf 000000
no vad
dial-peer voice 105 voip
description *** Outbound LAN Side Dial-Peer (INCOMING CUCM Publisher) ***
destination-pattern 3....
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 106 voip
description *** Outbound LAN Side Dial-Peer (INCOMING CUCM Subscriber-1) ***
voice-class codec 1
dtmf-relay rtp-nte
no vad
Please advise.
Thx
There is nothing that routes the resulting translated number to CM in your posted configuration. Correct that and it would likely work. Assuming you have the needed configuration in-place in CM obviously.
Response Signature
Another observation is that your dial peer to the subscriber is H323. Is that intentional?
Response Signature
Hai Roger Kallberg
Have a nice day,
i've routed dial-peer to cucm.
x.x.x.x is CUCM IP, so x is't published.
I don't use voice class h323 on Ip phone device or dial-peer, why you mention it ?
Please advise.
Thx
Your dial peers that have a destination pattern is different.
voice-class codec 1
dtmf-relay rtp-nte
no vad
This has session protocol sipv2, that makes it a SIP dial peer.
voice-class codec 1
dtmf-relay rtp-nte
no vad
This does not have any session protocol defined, so it will use the default and that's H.323.
Have you done a debug ccsip message to see that the call is sent to CM? I personally don't like the use of dial peer as both inbound and outbound, but it for sure should work with proper configuration. Do you see that the call is hitting the dial peer 2001 and then using the same in the outbound direction?
Response Signature
