09-01-2016 04:45 PM
Good afternoon,
I'm having a problem. I have a pseudo account in PCP that I created for conference and lobby phones. I currently have one endpoint associated to it and when I try to add another I receive the error:
Failed to create user object instance. DFC Exception IM-0036 [CRITICAL]: Storing instance: Database exception:Message: ERROR: current transaction is aborted, commands ignored until end of transaction block SQL Errorcode: 0 SQL State: 25P02
The endpoint is created in PCP and is shown as 'In use" but it does not show up under the Pseudo user that the device was provisioned for.
Thoughts? Thank you for your time.
Solved! Go to Solution.
09-02-2016 01:36 PM
Hi Mike,
I was able to reproduce this when using the "Quick Provisioning" workflow ; Looks like a new defect. Hope you encountered this on the same flow as well - Appreciate your confirmation.
Workaround is to use "Custom Service Wizard" (traditional wizard method) workflow for endpoint provisioning. I shall log a defect and get this fixed.
09-02-2016 01:36 PM
Hi Mike,
