Jabber Android issue
Siva chinap
Level 5
Level 5
We have configured Jabber for Android, For some of the users; jabber client is automatically fetching profile picture from local phone or google account. We tried resetting/reinstalling Jabber client, still the profile picture appears on Jabber. How to remove it?
RachelGomez161999
Troubleshooting Cisco Jabber for Android
1.) Setup Issues
Cisco Jabber registration fails
Cisco Jabber registration fails or times out.The following list describes different possible causes for and solutions to registration failure or timeout conditions:
Verify that the mobile device can reach Cisco Unified Communications Manager: Try using the browser on the device to connect to the Cisco Unified Communications Manager Administration portal.
If registration is rejected with error 503, go to the Cisco Dual Mode for Android device page in Cisco Unified Communications Manager and select Reset, and then try again.
Make sure your DNS server can resolve the hostname of the Cisco Unified Communications Manager server that is used as the TFTP server address.
Enter the IP address instead of the hostname of the Cisco Unified Communications Manager server into the TFTP Server Address setting in Cisco Jabber.
If registration fails with the error message "Verification Timed Out," you did not reboot all Cisco Unified Communications Manager servers in the cluster after you installed the device COP file. To resolve the error, reboot all Cisco Unified Communications Manager servers.
Make sure you have enough licenses to accommodate your deployment.
Have the user check that the device connects to the corporate Wi-Fi. If the Wi-Fi is a custom Wi-Fi and it is not checked on the Custom Wi-Fi Networks screen, Cisco Jabber will not try to register.
If the value in System > Server in Cisco Unified Communications Manager is a hostname without a domain, enter your domain name in the Domain Name field in the Cisco Dual Mode for Android device page.
Directory server handshake error
When the client attempts to connect to the directory server, the connection fails with an SSL Handshake error.
Change the Enable LDAP SSL setting on the device page in Cisco Unified Communications Manager and relaunch the application.
Device icon is missing
The device icon in the Unified CM Administration pages does not appear.
Try the following:-
Restart the Tomcat service as described in Install Cisco Options Package file for devices.
Reload the device page in your browser.
Clear the browser cache if necessary.
2.) Device Issues
Cisco Jabber registration drops frequently
Unified CM registration drops frequently when the user's device is idle.
Verify the SIP Profile settings in Unified CM Administration. For more information, see Create dedicated SIP Profile.
Cannot complete calls
Numbers that should be dialable cannot be connected. Users hear a network busy tone or error message.
Try the following:
If you made changes to the Application Dial Rules, make sure you ran the COP file to make the changes available to Cisco Jabber, and that you restarted the TFTP service.
If you modified the dial rules and specified an alternate location for the dial rules in the Product Specific Configuration Layout section on the device page, make sure that you updated the custom file before you restarted the TFTP service.
Make sure that you set the Call Forward Unregistered settings on the device page.
Calls incorrectly sent to voicemail
Calls are routed directly to voicemail.
In Unified CM, modify the call timer values on the Mobile Identity page. For more information see Add Mobile Connect and Mobile Identity.
3) Secure connect issues
Secure connect no longer connects
User could previously connect to the corporate network using secure connect, but now cannot connect.
Try one of the following:
On the Cisco Jabber for Android device, verify that the user has set the correct group. If the user has a SCEP group, ensure that the user did not select the SCEP group instead of the authentication group.
If the user is set up with one-time password authentication, ask the user to check whether the password is expired. When the password expires, the user sees an error message.
If the user is set up with certificate-based authentication, check whether the certificate has expired.
Check to see if the group name was changed. If so, the user should delete the previously configured connection and add a new connection. For information about deleting and adding a connection for secure connect, see End User Guide
Verify that the ASA license is still valid.
Verify that the gateway is reachable.
Verify that the user can connect to the corporate network.
If the user performs initial setup of Cisco Jabber while the Android device is remotely connected to the corporate network using Cisco AnyConnect, Cisco Jabber adds the remote network to the Custom Wi-Fi Networks list. When your device is connected to a checked network on this list, secure connect does not launch. The user must uncheck the check box for the remote (non-corporate) network. To access the Custom Wi-Fi Networks list, go to the Cisco Jabber home screen and tap Menu > Settings > General > Wi-Fi Networks > Custom Wi-Fi Networks.
4) UCM SIP 503 error - Cisco Jabber mobile client unable to register
Cisco Jabber for Android gets 503 response repeatedly from UCM while trying to register.
Cisco Jabber for Android device is enabled with Cisco Unified Mobile Communicator. While it was being group reset via the Admin portal and before the new device instance wass completely ready, the Jabber client sent in Wifi registration and immediately unregistered itselk right after its WiFi registration is accepted. Refresh registration after that was always rejected with 503.
This may help you,
Rachel Gomez
