Jabber for Android
Garima Parghi
We have Jabber for Android on the internal wi-fi network. everything works fine but every 30mins or so the App times out or resets.  I have attached the pic of the timeout window on the phone.
Has anyone experienced this. I am running CUCM 9.1.2 IM&P 9.1.1 and the Jabber App is 11.6. I have recently uploaded the latest Jabber for Android cop file.
any help is appreciated.
thank you,
Jaime Valencia
You would need to look at a PRT to see if this is caused by the device itself, or if this is something on the server, or network.
I only see one honeywell device in the supported devices list, is that the model you're using??
java
if this helps, please rate
Yes we are using the approved Honeywell CT50 model. I have a TAC case opened and waiting for their response.
thank you for your reply!
