07-27-2016 12:25 AM - edited 03-19-2019 11:24 AM
We have CUCM 10.5 and we use jabber clients for iphone (Phone services only).
Jabber registers and calls are successful. Our problem is that, when we try to search contact in corporate directory it doesn't work.
We have integrated CUCM to AD using LDAP.
We tried to configure LDAP parameters in "Product Specific Configuration Layout" but still no success... (see attachment)
any ideas?
07-27-2016 12:48 AM
the setting which you have mentioned don't take effect.
please configure a jabber-config xml file in which you will have a directory server defined and upload this file on your tftp server. for example , make a jabber-config.xml file as below :
<?xml version="1.0" encoding="utf-8"?>
<config version="1.0">
<Client>
<jabber-plugin-config>
<browser-plugin>
</browser-plugin>
</jabber-plugin-config>
<Directory>
<DirectoryServerType>EDI</DirectoryServerType>
<ConnectionType>1</ConnectionType>
<PrimaryServerName>x.x.x.x</PrimaryServerName>
<ServerPort1>specify port number</ServerPort1>
<ConnectionUsername>please define connection musername</ConnectionUsername>
<ConnectionPassword>pleas define password</ConnectionPassword>
<UseSecureConnection>0</UseSecureConnection>
<SearchBase1>please define search base</SearchBase1>
</Directory>
</config>
refer the below doc for your reference as well.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_6/CJAB_BK_C56DE1AB_00_cisco-jabber-106-deployment-and-installation-guide/CJAB_BK_C56DE1AB_00_cisco-jabber-106-deployment-and-installation-guide_chapter_01111.html
i hope this will resolve your issue.
07-27-2016 02:42 AM
Thanks for reply
I've tried xml configuration. Jabber client from iphone gets jabber-config.xml, I saw in AD that the username and password from jabber-config.xml tried to login and it was successful, but anyway it doesn't work...
here is xml config:
<Client>
</Client>
<browser-plugin>
</browser-plugin>
<Directory>
<PrimaryServerName>AD-IP</PrimaryServerName>
<ServerPort1>389</ServerPort1>
<ConnectionUsername>Voip-admin@AD</ConnectionUsername>
<ConnectionPassword>password</ConnectionPassword>
<SearchBase1>OU=search,DC=base,DC=com</SearchBase1>
</Directory>
</config>
07-27-2016 03:19 AM
a small correction. in my last email , i mentioned directory type as EDI. It is wrong.
EDI is for windows client
BDI is for non-windows clients.
so in that case , your jabber-config xml file should be as below :
<Client>
</Client>
<browser-plugin>
</browser-plugin>
<Directory>
<DirectoryServerType>BDI</DirectoryServerType>
<BDILDAPServerType>AD</BDILDAPServerType>
<BDIPrimaryServerName>X.X.X.X</BDIPrimaryServerName>
<BDIServerPort1>389</BDIServerPort1>
<BDIConnectionUsername>Voip-admin@AD</BDIConnectionUsername>
<BDIConnectionPassword>Password</BDIConnectionPassword>
<BDISearchBase1>OU=search,DC=base,DC=com</BDISearchBase1>
</Directory>
</config>
07-27-2016 04:29 AM
I've change the config as you wrote but still no success...
I looked up packet capture on cucm and saw that jabber client gets jabber-config.xml, but when I try to search in corporate directory it didn't even try to connect to ldap (I saw connection log in ASA)
anything else?
Thanks one more time
07-27-2016 04:34 AM
if jabber is able to download the config xml file then there is something missing in config file. it may be a credentials issue or jabber is unable to reach the ldap server
07-27-2016 04:45 AM
Jabber client doesn't even try to connect to AD for corporate directory - I was watching live monitoring on ASA
07-27-2016 08:16 AM
<Client>
</Client>
<Directory>
</Directory>
</config>
use the above config and below link to check if there is any syntax issue in file.
http://www.xmlvalidation.com/
also make sure you naming file as jabber-config.xml file.
I tried the same in my lab for iphone and it worked
