Jabber MRA one way audio - EXP 12.5.7 CUCM 11.5
engmouafy
Hello all,
any thoughts regarding the below ?
Call Setup:
(A)Jabber Mobile/Desktop
(B)PSTN Mobile Number
(A) --MRA--EXPs --> CUCM --SIPTrunk --> Provider --> (B)
B can hear A but A can't hear B -- if B pressed on any digit during the call, two ways stream start and A can hear B
from EXP-C logs to CUCM if no dtmf pressed:
RTP-RxStat: Dur=35,Pkt=0,Oct=0,LostPkt=0,AvgJit=0,VqMetrics="CS=0;SCS=0"
RTP-TxStat: Dur=35,Pkt=1663,Oct=266080
if jabber is over vpn or onsite the same call goes fine.
MRA Setup:
EXP-E Dual NIC -- Public IP is configured on LAN2 - No NAT
Note: MRA to MRA// MRA to internal - no issues
screen shot from Jabber mobile - Receiving none
Ayodeji Okanlawon
This looks like a firewall related issue.. I would ask the firewall guys to check why media is being denied. That's where I would start.
You can also take Wireshark capture on PC and provide the ports that is negotiated for the session to the firewall team.
Please rate all useful posts
It is a local ISP issue
If you know what the cause is and have solved it would you mind to give a little more details about this for the greater good of the community?
Response Signature
