Latest Firmware for VG310
mumbles202
Level 5
Level 5
I was attempting to download the latest firmware for the 310 and went here (Downloads Home --> Unified Communications --> Communications Gateways --> Voice Gateways --> VG Series Gateways --> VG3X0 Analog Voice Gateways
Software Download - Cisco Systems
I see that 15.9.3M11 is listed there, but when I read the release notes it doesn't list either the VG310 or the VG320 so wanted to confirm it is in fact supported for that platform.
Vaijanath Sonvane
Hi @mumbles202,
This version is supported for VG310 and VG320. You can also verify this at below URL:
https://www.cisco.com/c/en/us/support/unified-communications/vg-series-gateways/series.html#~tab-downloads
Select the model and it will show available software for this product.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
Hi @mumbles202,
mumbles202
Level 5
Level 5
Thanks a lot.  I didn't see them in the release notes but had seen the others so wanted to confirm.
