Managing BLF Keys for Multiple Phones with Expansion Modules
I am looking for a way to manage BLF Key assignments from a single source that is then pushed to multiple phones.
Basically I want to have 6x 8865 phones w/ expansion modules to mimic assigned BLF keys but all having different line assignments and ext numbers as well.
This is individual configuration in CM, so it would be one place to manage it, ie the admin webUI of CM, but it would not be one configuration. You’ll need to repeat the configuration the number of times you have devices that should have the BLFs.
Response Signature
To add a tip to what @Roger Kallberg corre suggested, you could use Bulk Administration Tool to update and distribute Speed Dials in one shot.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Good suggestion @Carlo Poggiarelli
Response Signature
