10-16-2012 01:27 PM - edited 03-19-2019 05:44 AM
Can I run the Application and the Scheduling(Web) servers on the same physical server, or do they require a dedicated serverfor each application.
10-17-2012 04:36 PM
Just to let you know few things here, both are differnet.
Application server run's Linux, while, Web Server is installed on Windows platform so you need 2 or more boxes for the same.
But, just remember MP 8.5 new install does not support web server, only migration from previous versions. If you want to schedule web meeting you need to integrate your MP with WebEx cloud (so need a webex site) , otherwise with new install it's audio only.
Arun
10-17-2012 07:37 PM
I am upgrading from MPE 2.1 to MP8.5, audio only. Customer would like to retain the Web scheduler function in MPE. So, separate servers will be required, and I assume this would still be true in a Virtual environment as well?
10-18-2012 08:14 AM
Yes, right. No matter what is the case you need different server for application and web.
Arun
