Migrate MCS to VM
Yazen Alaa
Dear All
i have MCS version 5.1(2) to UCS VM version 11.0
i read these steps below :
A) Migrate the legacy W1/L2 to 6.1(5) or 7.1(5)
B) Migrate PCD M1 to 11.0
Step A and B will do both in  UCS VM server , it is right ? if not how it will be ? becasue it is not clear for me
thanks
Jaime Valencia
No, right now you need to upgrade, still on MCS, to one release which is supported by PCD to migrate from.
THEN, you will install PCD over ESXi, and configure the migration task.
java
if this helps, please rate
