Migration of Unity Connection from 8.6 to 10.x
Jagsuvce G
Am planning to upgrade from Unity Connection 8.6 to Unity connection 10.x. My current unity connnection 8.6 is running on Cisco MCS 7825 H3 Hardware.
As my UCS upgrade license is expiring in another 15 days, am planning to upgrade the latest available version.
Is MCS 7825 H3 is compatible for 10.x unity connection and can i directly upgrade from 8.6 to 10.x .
Pls suggest
You are correct.
regds,
aman
10 Replies 10
Aman Soi
Hi Jagadish,
please refer the link which says
Cisco Unity Connection 10.x is not pre-installed on any platform. Unity Connection 10.0(1) and later can only be installed on virtual machines. Cisco Unity Connection 10.x is not pre-installed on any platform. Unity Connection 10.0(1) and later can only be installed on virtual machines.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/supported_platforms/10xcucspl.html
You can refer the link for upgrade
you can upgrade from unity connection 8.6 to 10.x
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/upgrade/guide/10xcucrugx/10xcucrug025.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/upgrade/guide/10xcucrugx/10xcucrug010.html#61567
regds,
aman
Thanks for the respone. So first i need to upgrade to 9.x on  same MCS 7835 H3 hardware. Take a DRS Backup and restore it on VMware machine with 9.x installed and then plan for 10.x upgrade Right ??
Also this will eat 2 upgrade license right ??
Jagadish
Hi Jagadish,
you can migrate directly to 10.x
for licenses , u can refer the heading  "Using Upgrade Process" under link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/upgrade/guide/10xcucrugx/10xcucrug010.html#pgfId-1137107
regds,
aman
Hi Aman,
I think this link says if am already on VMware with 8.6 and then i can  upgrade to 10.x. Right ??
My situation is currently am running Unity Connection 8.6 on MCS 7825 H3 and i need to move to the latest available Unity Connection version. What is the best way.. Pls suggest.
Also will 9.x or 10.x Unity connection can be integrated with CUCM 8.6 ??
Pls let me know the best way am literally confused.
Jagadish
Hi Jagadish,
UCXN 7 and above is supported with CUCM 10.
you can refer table 1 in link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
regds,
aman
Hi Aman,
So my understanding is..
First .....
1) From the Physical Server take a DRS Backup.UC 8.6
2) Create the VMware Session for 10.x with respective ova template required for 5000 users.
3) Intall the 10.x with same config like hostname ip etc.. Both PUB & SUB.
4) Restore the DRS Backup of 8.6..on 10.x VM ware
5) With the help of cobras migrate the licenses.
Second
1) From the Physical server take a DRS Backup of UC 8.6.
3) Install the 8.6 (same version) on vmware with same config like hostname ip etc..Pub & Sub.
4) Restore the DRS Backup on vmware.
5) Get the license from cisco.
6) The upgrade the UC 8.6 to 10.x ..
Which is correct aman First or Second.
Also am confirmed that Unity Connection (UC) 10.x can be integrated with CUCM 8.6.
Jagadish
Hi Jagadish,
You need to follow second option.while restoring, u need to have exactly same versions.
Unity connection 7.x  or in your case 8.6  is compatible with call manager 10.x or lower CUCM versions
regds,
aman
Thanks Aman,
So i need to follow this...
Second Option
And wrt compatibility my CUCM remains on 8.6 version and unity connection moves to 10.x version. Hope this fine.
You are correct.
regds,
aman
Thanks aman.
