Migration with PCD - Phone ITL fiels
cbrasolin
Level 4
Level 4
 Using PCD for migrating a CUCM 8.6 cluster with security disable, do i need to take in consideration the phone ITL files as described in the link below?
https://supportforums.cisco.com/document/60716/migrating-ip-phones-between-clusters-cucm-8-and-itl-files
The PCD migration guide does not mention any step about the phone ITL files. Will the PCD handle the certificate task by himself?
Thanks and Regards,
Christian
Manish Gogna
Hi Christian,
All the scenarios involving simple migration ( keeping same ip address and hostname ) and network migration ( changing ip addr or hostname ) for secure and non secure clusters are covered under "Run a Migration Task" section of the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/10_5_1/CUCM_BK_U35347D2_00_pcd-administration-guide-1051/CUCM_BK_U35347D2_00_ucmap-administration-guide-1051_chapter_010.html#CUCM_RF_S42FB70D_00
Unified CM source cluster - from ReleaseSimple Migration or Network MigrationUnified CM source cluster - (secure or nonsecure)User procedures to be performed during migration
6.1(5), 7.1(3), 7.1(5)
Simple migrationSecureNo steps are required during migration
Simple migrationNonsecureNo steps are required during migration
Network migrationSecureWhen migration task reaches the Forced Pause step, click the Resume button.
Network migrationNonsecureWhen migration task reaches the Forced Pause step, click the Resume button.
8.x, 9.x, and 10.x
Simple migrationSecureNo steps required during migration
8.x, 9.x, and 10.x
Simple migrationNonsecureNo steps required during migration
8.x, 9.x, and 10.x
When the migration task reaches the Forced Paused step, perform the following steps:
  1. CTL Update
  2. Bulk Certificate Management
  3. Resume the task on Cisco Prime Collaboration Deployment GUI.
8.x, 9.x, and 10.x
  1. Bulk Certificate Management
  2. Resume the task on Cisco Prime Collaboration Deployment GUI.
Postmigration Tasks for Cisco Unified Communication Manager Nodes in the Cluster
"After the migration task runs successfully, if a migration task with network migration was performed, some additional steps are required. (No postmigration tasks are required if a simple migration was performed.) "
Consult the following table and the applicable migration Use Case flowchart to determine whether any user tasks must be performed after the migration task is successful.
Unified CM source cluster - from ReleaseSimple Migration or Network MigrationUnified CM source cluster (Secure or Non-secure)User procedures to be performed after migration
  1. Perform CTL Update
  2. Restart Services on Unified Communications Manager
  3. Change TFTP Server IP Address
  4. Verify Phone Registration
  1. Change TFTP Server IP Address
  2. Verify Phone Registration
8.x, 9.x, and 10.x
Manish
- Do rate helpful posts -
Manish Gogna
Hi Christian,
8.x, 9.x, and 10.x
8.x, 9.x, and 10.x
8.x, 9.x, and 10.x
  1. CTL Update
8.x, 9.x, and 10.x
8.x, 9.x, and 10.x
Manish
Thanks Manish,
 i was talking about a simple migration, nice to see that i don't have to worry about ITL files.
Thx a Regards,
Christian
