Missed call notification through e-mail using Unity Connection
marahman78
Could we configure Unity Connection for missed call notification, once there is a missed call the notification will be send by email to that user ?
17 Replies 17
cbarlow
We are planning to introduce missed call notifications with Unity Connection in Q4CY14.  As this is a road mapped feature, the delivery of the feature and/or the timing of the delivery of the feature may change prior to FCS.
-Chris Barlow
Cisco Unity Connection Product Manager
Just an update here.  The delivery date for this feature has been moved to Q2CY15.  As this feature is still pre-FCS,
-Chris Barlow
Thanks for an update
Chris,
Is this going to be a 10x or 11x release feature?
-Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hi Bill,
This will be an 11.x feature.
-Chris Barlow
Hey Bill
Any chance unity will look at the user's exchange contacts and match it, then provide the contact info in both the VM or the missed call notification?
Hi Bill,
Not at this moment.  Might be something we can pick up in a future release.  Can't guarantee anything, but we'll look at it.
-Chris Barlow
Hello Chris,
Is this feature available now? Kindly advise.
Joshua
Yes in version 11
Srini
Hi Srini,
How we can use this feature in Version 11.x ?
just implementing this on Unity Con 11.5 and wanted to see if there is a way to enable this globally from user template, i do see the option under user template however not sure about the email address format that will go in "to" field. It probably requires a format instead of individual email but not seeing anything in documentation
Were you able to find a way to get this to work?  Is there a variable I could add here to tell the template to use the users corporate email?
You may use bat file to update email id. template currently doesnot allow to inherit corporate email id .
