**Mobile Voice Access (MVA) prompt not playing**
Hi friends,
I have sucessfully configured MVA with another customer using isdn gateway, the thing is that now im unable to get working this service in R2 signaling
or maybe im missing something, While debugging the application, vxml script appears but no prompt is played and after a few moment the call drops.
MVA Service is already activated, MVA DN as well, RDP and profiles assigned to users, mobility softkey done.
Can you guys help me figure out whats hapenning?  Thanks in advance!
CUCM: 8.6.2.21900-5 VMWare
IOS: c3900-universalk9_npe-mz.SPA.153-2.T.bin
application
service mva http://10.10.11.10:8080/ccmivr/pages/IVRMainpage.vxml
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
dial-peer voice 4665 pots
service mva
incoming called-number 4666
no digit-strip
direct-inward-dial
port 0/0/0:1
dial-peer voice 4666 voip
destination-pattern 4666
session target ipv4:10.10.11.10
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
______________________________________________________
#sh call application voice mva
Script Name : mva
       URL  : http://10.10.11.10:8080/ccmivr/pages/IVRMainpage.vxml
       Type : Service
       State: Registered
       Life : Configured
       Exec Instances: 1
Script Code Begin:
VXML Application mva
    URL=http://10.10.11.10:8080/ccmivr/pages/IVRMainpage.vxml
    Security Level: not trusted
            2 incoming calls
            0 calls handed off to it
            0 call transfers initiated
            0 pages loaded,  4 successful
            0 prompt play attempts, 0 successful
            0 recorded messages
The VXML Script is:
<?xml version="1.0" encoding="iso-8859-1"?>
<vxml version="2.0">
   <form id="main">
      <block>
       <prompt>
          <audio src="http://10.10.11.10:8080/ccmivr/IVRGetAudioFile.do?srcdir=en_US&file=1.au"/>
        </prompt>
        <var name="remotedest" />
        <assign name="remotedest" expr="session.telephone.ani"/>
        <var name="srcdir" />
        <assign name="srcdir" expr="'en_US'"/>
        <if cond="remotedest !='blocked' " >
           <submit next="http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do" method="get" namelist="remotedest srcdir"/>
        <else />
           <goto next="#Getremotedest"/>
        </if>
      </block>
   </form>
   <form id="Getremotedest">
      <grammar type="application/grammar+regex">.</grammar>
      <field name="get_remotedest" type="digits?minlength=1;maxlength=50">
         <prompt>
          <audio src="http://10.10.11.10:8080/ccmivr/IVRGetAudioFile.do?srcdir=en_US&file=3.au"/>
         </prompt>
         <noinput count="3">
         <exit/>
         </noinput>
         <filled>
           <var name="dest" />
        <assign name="dest" expr="get_remotedest"/>
           <var name="accessCount" />
        <assign name="accessCount" expr="1"/>
           <submit next="http://10.10.11.10:8080/ccmivr/IVRCalleridLookup2.do" method="get" namelist="dest srcdir accessCount"/>
         </filled>
      </field>
   </form>
</vxml>
____________________________________________________________________________________________________-
RT3925_TSN#
*Jun 12 18:20:01.017: //-1/879C783F856F/CCAPI/cc_api_call_setup_ind_common:
   Sub Calling(TON=Unknown, NPI=Unknown, DataA'7L, Length=2)
*Jun 12 18:20:01.021: //-1//VXML:EE01041660000:/C_ServiceVxmlBase_Main:
*Jun 12 18:20:01.021: //15848//VXML:/Open_SetupIndication:
*Jun 12 18:20:01.021: //15848//AFW_:/vapp_vxmldialog: Trusted=0, DNIS Map URI=, Code = {
*Jun 12 18:20:01.021: //15848//AFW_:/vapp_vxmldialog: After DNIS Map URI=http://10.10.11.10:8080/ccmivr/pages/IVRMainpage.vxml, Code = {
   <form id="
*Jun 12 18:20:01.021: //-1//AFW_:/AFW_VxmlModule_New:
*Jun 12 18:20:01.021: //-1//VXML:/vxml_tree_lock:
   vxmlp=413A2A14 usage_cnt=0
*Jun 12 18:20:01.021: //0/879C783F856F/VXML:/vxml_parse:
*Jun 12 18:20:01.021: vxml_parse: XML_Parse success err=0
*Jun 12 18:20:01.021: //0/879C783F856F/VXML:/vxml_session_delete:
*Jun 12 18:20:01.021: vxml_session_delete:mem_mgr_mempool_free: mempool=NULL
*Jun 12 18:20:01.021: //-1//VXML:/vxml_crc_generate_element_tree: 28 crc generated
*Jun 12 18:20:01.021: //-1//VXML:/vxml_create:
   enter url=http://10.10.11.10:8080/ccmivr/pages/IVRMainpage.vxml tree_handle=413A2A14
   return_handle_add=2304C28
*Jun 12 18:20:01.025: //-1//VXML:/vxml_create: Exit
*Jun 12 18:20:01.025: //15848//AFW_:/vapp_checksessionstate:
*Jun 12 18:20:01.025: //15848//AFW_:/vapp_checkifdone: Object: 1, Leg: 1
*Jun 12 18:20:01.025: //15848//AFW_:/vapp_driver: evtID: 240 vapp record state: 0
*Jun 12 18:20:01.029: //15848//AFW_:/vapp_get_type_detail:
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_offramp_mailhdrs_get:
*Jun 12 18:20:01.029: //15848//AFW_:/vapp_get_incoming_gtd_list:
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_jse_add_gtd_obj_to_list:
   Sig-event name = setup_indication, gtd-len = 46, gtd-buf =
IAM,
GCI,879c783fd2c311e2856ff180b4a4d6f8
   gtd_obj for sig-event [setup_indication] added to session/shadow
   var array [0x40027BF0]
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_create_gtd_sess_vars:
   Created object chain for com.cisco.signal.gtdlist
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_start:
   vxmlhandle=14C70214 vapphandle=10B2D9BC status=0 async_status=0
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_vxml_proc:
<vxml>
   URI(abs):http://10.10.11.10:8080/ccmivr/pages/IVRMainpage.vxml
   scheme=http
   host=10.10.11.10
   port=8080
   path=/ccmivr/pages/IVRMainpage.vxml
   base=
   scheme=http
   host=10.10.11.10
   port=8080
   path=/ccmivr/pages/IVRMainpage.vxml lang=none version=2.0
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_form_proc:
*Jun 12 18:20:01.029:  <form>: id=main   scope=dialog
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_form_init:
   current scope: dialog
   vxml_counter_reset:
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_expr_eval:
*Jun 12 18:20:01.029:    expr=var _in0
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_jse_global_switch:
   switch to scope(dialog)
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_formitem_select:
   Status=VXML_STATUS_OK,
    AsyncStatus=VXML_STATUS_OK
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_block_proc:
*Jun 12 18:20:01.029:   <block>:
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_item_attrs_proc:
   name=_in0
*Jun 12 18:20:01.029: //-1//VXML:/vxml_prompt_proc: Enter
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_prompt_proc:
         <prompt>: typeaheadflush=0 alternative=0
*Jun 12 18:20:01.029: //-1//VXML:/vxml_process_prompt: Enter
*Jun 12 18:20:01.029: //-1//VXML:/vxml_audio_proc: Enter
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_audio_proc:
         <audio>:
   URI(abs):http://10.10.11.10:8080/ccmivr/IVRGetAudioFile.do?srcdir=en_US&file=1.au
   scheme=http
   host=10.10.11.10
   port=8080
   path=/ccmivr/IVRGetAudioFile.do
   query=srcdir=en_US&file=1.au caching=fast fetchhint=invalid fetchtimeout=0 maxage=-1 maxstale=-1
*Jun 12 18:20:01.029: //-1//VXML:/vxml_audio_proc: Exit
*Jun 12 18:20:01.029: //-1//VXML:/vxml_finish_generate_prompt_list: Enter
*Jun 12 18:20:01.029: //-1//VXML:/vxml_finish_generate_prompt_list: Exit
*Jun 12 18:20:01.029: //-1//VXML:/vxml_process_prompt: Exit
*Jun 12 18:20:01.029: //15848/879C783F856F/VXML:/vxml_vapp_media_play:
   bargein=1 timeout=0 typeaheadflush=0 vcr=0 rate=0 alternative=0 hotword=0 maxtime=0
   str=http://10.10.11.10:8080/ccmivr/IVRGetAudioFile.do?srcdir=en_US&file=1.au cachable=1 timeout0 maxage=-1 maxstale=-1 codec=-1
*Jun 12 18:20:01.029: //15848//AFW_:/vapp_media_play:
*Jun 12 18:20:01.029: //15848//AFW_:/vapp_media_play: prompt=http://10.10.11.10:8080/ccmivr/IVRGetAudioFile.do?srcdir=en_US&file=1.au:
*Jun 12 18:20:01.377: //-1//VXML:/vxml_vapp_media_play: Exit
*Jun 12 18:20:01.377: //-1//VXML:/vxml_prompt_proc: Exit
         <var>: namep=remotedest
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_expr_eval:
*Jun 12 18:20:01.377:    expr=var remotedest
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_jse_global_switch:
   switch to scope(anonymous)
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_assign_proc:
         <assign>: name=remotedest expr=session.telephone.ani
*Jun 12 18:20:01.377:    expr=remotedest=session.telephone.ani
         <var>: namep=srcdir
*Jun 12 18:20:01.377:    expr=var srcdir
         <assign>: name=srcdir expr='en_US'
*Jun 12 18:20:01.377:    expr=srcdir='en_US'
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_if_proc:
         <if>: cond=remotedest !='blocked'
*Jun 12 18:20:01.377: //-1//VXML:/vxml_submit_proc: Enter
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_submit_proc:
            <submit>: caching=fast fetchhint=invalid fetchtimeout=0 maxage=-1 maxstale=-1
   URI(abs):http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do
   scheme=http
   host=10.10.11.10
   port=8080
   path=/ccmivr/IVRCalleridLookup.do
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_sub_attrs_proc:
   method=get
   enctype=application/x-www-form-urlencoded
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_nmtokens_proc:
   name=remotedest
   name=srcdir
*Jun 12 18:20:01.377: //-1//VXML:/vxml_sub_attrs_proc: Enter
*Jun 12 18:20:01.377: //-1//VXML:/vxml_sub_attrs_proc: Exit
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_vapp_bgload_from_proc:
   urlp=http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do?remotedest=8114967222&srcdir=en_US fetchaudio=NULL delay=0 minimum=0
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_vapp_bgload:
   url http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do?remotedest=8114967222&srcdir=en_US cachable 1 fetchtimeout 0 maxage=-1 maxstale=-1
*Jun 12 18:20:01.377: //15848//AFW_:/vapp_bgload: url=http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do?remotedest=8114967222&srcdir=en_US
*Jun 12 18:20:01.377: //15848//AFW_:/vxml_update_cleanup_timer: cleaning timer running 0 fetchtimeout 0
*Jun 12 18:20:01.377: //-1//VXML:/vxml_vapp_bgload: Exit
*Jun 12 18:20:01.377: //-1//VXML:/vxml_vapp_bgload_from_proc: normal_async_load, exit@8275
*Jun 12 18:20:01.377: //-1//VXML:/vxml_submit_proc: Exit
*Jun 12 18:20:01.377: //-1//VXML:/vxml_elem_proc:
(400000000) Status not OK, exit@9984
*Jun 12 18:20:01.377: //-1//VXML:/vxml_if_proc:
(400000000) Status not OK, exit@5740
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_leave_scope:
   scope=anonymous
*Jun 12 18:20:01.377: //-1//VXML:/vxml_block_proc: Exit (400000000)
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_formitem_select:
   loop cnt=0,
*Jun 12 18:20:01.377: //-1//VXML:/vxml_formitem_select:
(400000000) Status not OK, exit@5419
*Jun 12 18:20:01.377: //-1//VXML:/vxml_form_proc:
(400000000) Status not OK, exit@5551
*Jun 12 18:20:01.377: //-1//VXML:/vxml_vxml_proc:
(400000000) Status not OK, exit@10181
*Jun 12 18:20:01.377: //15848/879C783F856F/VXML:/vxml_load_immediate_done:
   sidp->status=400000000
*Jun 12 18:20:01.377: //15848//AFW_:/vapp_checksessionstate:
*Jun 12 18:20:01.377: //15848//AFW_:/vapp_checkifdone: Object: 1, Leg: 1
*Jun 12 18:20:01.385: //15848//AFW_:/vapp_driver: evtID: 43 vapp record state: 0
*Jun 12 18:20:01.385: //15848//AFW_:/vapp_checksessionstate:
*Jun 12 18:20:01.385: //15848//AFW_:/vapp_checkifdone: Object: 1, Leg: 1
*Jun 12 18:20:01.461: //15848//HIFS:/hifs_http_cb: hifs http read succeeded. size=853, url=http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do?remotedest=8114967222&srcdir=en_US
*Jun 12 18:20:01.461: //15848//AFW_:/vapp_bgload_done: status=No Error
*Jun 12 18:20:01.461: //15848//HIFS:/hifs_http_cb: hifs ifs file read succeeded. size=853, url=http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do?remotedest=8114967222&srcdir=en_US
*Jun 12 18:20:01.461: //15848//HIFS:/hifs_free_idata: hifs_free_idata: 0x40C46F68
*Jun 12 18:20:01.461: //15848//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x40C46F68
*Jun 12 18:20:01.461: //15848//AFW_:/vapp_driver: evtID: 285 vapp record state: 0
*Jun 12 18:20:01.461: //15848//AFW_:/vapp_bgload_done_event:
*Jun 12 18:20:01.461: //15848//AFW_:/vapp_bgload_done_event: length=853, page loaded=
<form id="RemoteDest">
    <field name="dest" type="digits?minlength=1;maxlength=50">
      <prompt>
         <au
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_is_doc:
   vxml_is_doc
*Jun 12 18:20:01.461: //-1//VXML:/vxml_tree_lock:
   vxmlp=136A7E10 usage_cnt=0
*Jun 12 18:20:01.461: //0/879C783F856F/VXML:/vxml_parse:
*Jun 12 18:20:01.461: vxml_parse: XML_Parse success err=0
*Jun 12 18:20:01.461: //0/879C783F856F/VXML:/vxml_session_delete:
*Jun 12 18:20:01.461: vxml_session_delete:mem_mgr_mempool_free: mempool=NULL
*Jun 12 18:20:01.461: //-1//VXML:/vxml_crc_generate_element_tree: 17 crc generated
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_bgload_post_done:
   vxmlhandle=14C70214 status=0 async_status=400000000
   Loading file with url (http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do?remotedest=8114967222&srcdir=en_US)
*Jun 12 18:20:01.461: //-1//VXML:/vxml_is_cisco_data: Enter
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_leave_scope:
   scope=application
*Jun 12 18:20:01.461: //-1//VXML:/vxml_crc_verify_element_tree: 28 crc verified
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_tree_delete:
   vxmlp=413A2A14, usage_cnt=1 url=http://10.10.11.10:8080/ccmivr/pages/IVRMainpage.vxml
*Jun 12 18:20:01.461: vxml_tree_delete:mem_mgr_mempool_free: mem_refcnt(41370D14)=0 - mempool cleanup
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_stop_fetchaudio:
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_start:
   vxmlhandle=14C70214 vapphandle=10B2D9BC status=0 async_status=80000
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_vxml_proc:
<vxml>
   URI(abs):http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do?remotedest=8114967222&srcdir=en_US
   scheme=http
   host=10.10.11.10
   port=8080
   query=remotedest=8114967222&srcdir=en_US
   base=
   scheme=http
   host=10.10.11.10
   port=8080
   query=remotedest=8114967222&srcdir=en_US lang=none version=2.0
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_form_proc:
*Jun 12 18:20:01.461:  <form>: id=RemoteDest   scope=dialog
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_form_init:
   vxml_counter_reset:
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_expr_eval:
*Jun 12 18:20:01.461:    expr=var dest
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_jse_global_switch:
*Jun 12 18:20:01.461: //15848/879C783F856F/VXML:/vxml_formitem_select:
*Jun 12 18:20:01.465: //15848/879C783F856F/VXML:/vxml_formitem_select:
*Jun 12 18:20:01.465: //-1//VXML:/vxml_field_proc: Enter
*Jun 12 18:20:01.465: //15848/879C783F856F/VXML:/vxml_field_proc:
*Jun 12 18:20:01.465:   <field>: type=digits
*Jun 12 18:20:01.465: //15848/879C783F856F/VXML:/vxml_item_attrs_proc:
   name=dest modal=aai prompt_counter=1
*Jun 12 18:20:01.465: //-1//VXML:/vxml_play_prompts: Enter
*Jun 12 18:20:01.465: //-1//VXML:/vxml_prompt_proc: Enter
*Jun 12 18:20:01.465: //15848/879C783F856F/VXML:/vxml_prompt_proc:
*Jun 12 18:20:01.465: //-1//VXML:/vxml_process_prompt: Enter
*Jun 12 18:20:01.465: //-1//VXML:/vxml_audio_proc: Enter
*Jun 12 18:20:01.465: //15848/879C783F856F/VXML:/vxml_audio_proc:
         <audio>:
   URI(abs):IVRGetAudioFile.do?srcdir=en_US&file=3.au
   scheme=http
   host=10.10.11.10
   port=8080
   query=srcdir=en_US&file=3.au caching=fast fetchhint=invalid fetchtimeout=0 maxage=-1 maxstale=-1
*Jun 12 18:20:01.465: //-1//VXML:/vxml_audio_proc: Exit
*Jun 12 18:20:01.465: //-1//VXML:/vxml_finish_generate_prompt_list: Enter
*Jun 12 18:20:01.465: //-1//VXML:/vxml_finish_generate_prompt_list: Exit
*Jun 12 18:20:01.465: //-1//VXML:/vxml_process_prompt: Exit
*Jun 12 18:20:01.465: //-1//VXML:/vxml_prompt_proc: Exit
*Jun 12 18:20:01.465: //-1//VXML:/vxml_play_prompts: Exit
*Jun 12 18:20:01.465: //-1//VXML:/vxml_generic_digit_collect: Enter
*Jun 12 18:20:01.465: //15848/879C783F856F/VXML:/vxml_vapp_digit_collect:
   termchar # minlength 1 maxlength 50 timeout 15000 interdigittimeout 10000 numPatterns=0hotword 0 abortKey *
*Jun 12 18:20:01.465: //15848//AFW_:/vapp_digit_collect:
*Jun 12 18:20:01.465: //15848//AFW_:/vapp_digit_collect:  numPatterns 0, minlength 1, maxlength 50, timeout 15000, interDigitTimeout 10000 hotword 0
*Jun 12 18:20:01.465: //-1//VXML:/vxml_vapp_digit_collect: Exit
*Jun 12 18:20:01.465: //-1//VXML:/vxml_generic_digit_collect: Exit
*Jun 12 18:20:01.465: //-1//VXML:/vxml_field_proc: Exit
*Jun 12 18:20:01.465: //-1//VXML:/vxml_elem_proc:
(300000000) Status not OK, exit@9984
   loop cnt=0,
*Jun 12 18:20:01.465: //-1//VXML:/vxml_formitem_select:
(300000000) Status not OK, exit@5419
*Jun 12 18:20:01.465: //-1//VXML:/vxml_form_proc:
(300000000) Status not OK, exit@5551
*Jun 12 18:20:01.465: //-1//VXML:/vxml_vxml_proc:
(300000000) Status not OK, exit@10181
*Jun 12 18:20:01.465: //15848/879C783F856F/VXML:/vxml_load_immediate_done:
   sidp->status=300000000
*Jun 12 18:20:01.465: //-1//VXML:/vxml_bgload_post_done: Async load, exit@6789
*Jun 12 18:20:01.465: //-1//VXML:/vxml_bgload_post_done: return
*Jun 12 18:20:01.465: //15848//AFW_:/vapp_checksessionstate:
*Jun 12 18:20:01.465: //15848//AFW_:/vapp_checkifdone: Object: 2, Leg: 1
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_driver: evtID: 68 vapp record state: 0
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_checksessionstate:
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_checkifdone: Object: 2, Leg: 1
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_driver: evtID: 20 vapp record state: 0
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_call_disconnected: fetchtimeout 0
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_add_disconnected_gtd: Add GTD from disconnected event
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_user_hangup:
   duration 0 status=B async_status=300000000
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_event_proc:
         <event>: event=connection.disconnect.hangup status=0
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_expr_eval:
*Jun 12 18:20:04.377:    expr=var _event='connection.disconnect.hangup'
*Jun 12 18:20:04.377:    expr=var _message=undefined
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_default_event_handler:
   use default event handler
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_session_exit_event_name: Exit Event connection.disconnect.hangup
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_load_immediate_done:
   sidp->status=10
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_start:
   vxmlhandle=14C70214 vapphandle=10B2D9BC status=0 async_status=10
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_throw_error_session_event:
   async_status=10
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_vapp_terminate:
   vapp_status=0 ref_count 0
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_terminate:
*Jun 12 18:20:04.377: //15848//AFW_:/AFW_M_VxmlModule_Terminate:
*Jun 12 18:20:04.377: //-1//VXML:/vxml_destroy: Enter
*Jun 12 18:20:04.377: //-1//VXML:/vxml_crc_verify_element_tree: 17 crc verified
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_tree_delete:
   vxmlp=136A7E10, usage_cnt=1 url=http://10.10.11.10:8080/ccmivr/IVRCalleridLookup.do?remotedest=8114967222&srcdir=en_US
*Jun 12 18:20:04.377: vxml_tree_delete:mem_mgr_mempool_free: mem_refcnt(4033B0F0)=0 - mempool cleanup
*Jun 12 18:20:04.377: //15848/879C783F856F/VXML:/vxml_session_delete:
*Jun 12 18:20:04.377: vxml_session_delete:mem_mgr_mempool_free: mem_refcnt(41370D6C)=0 - mempool cleanup
*Jun 12 18:20:04.377: vxml_session_delete:mem_mgr_mempool_free: mempool=NULL
*Jun 12 18:20:04.377: //-1//VXML:/vxml_destroy: Exit
*Jun 12 18:20:04.377: //-1//VXML:/vxml_vapp_terminate: Exit
*Jun 12 18:20:04.377: //-1//VXML:/vxml_start: Exit
*Jun 12 18:20:04.377: //-1//VXML:/vxml_user_hangup: Exit
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_return_cleaner:
*Jun 12 18:20:04.377: //15848//AFW_:/vapp_checkifdone: Object: 1, Leg: 1
*Jun 12 18:20:04.377: //-1//AFW_:HN66E144F8:/AFW_M_VxmlModule_Free:
*Jun 12 18:20:04.377: MOD[VxmlModule_0x10B2D9BC_0_1726039288]   ( )
6 Replies 6
Any suggestion?
Thanks...
Does anyone has or had this issue?
did you configure everything on the CUCM side?
G.
Hi G,
I´ve double checked the configuration on CUCM like the
False
Complete Match
Mobile Voice Access Information
With these partial conf and the gateway configuration I should be able to hear the prompt but instead I receive a "disconnect Event: hangup" but the call drops by itself.
I wonder if it is a carrier issue but I need to make sure that i have everything fine.
thanks!
Sorry the number under the text box didnt appear
Did you marked / checked that RDN number with your desk number.
Please share the RTMT detailed trace also only for that particular instance.
Regards, Nishant Savalia
Hi Nishant,
As soon as I can I will post the trace result.
Thanks!
