Monitoring SIP Trunks in CUCM 12.x
n26neeraj
Hi Experts,
We have SIP trunks configured from the CUCM to the IMP and Unity servers. Whenever the SIP trunk is down, we would like to receive an Alert. Is it possible to do this  through a  MIB . Does CUCM 12.x support such MIB??
Could you please help me with the MIB or any documentation that could provide an insight on how we could achieve this?
Thanks in Advance
5 Replies 5
Vinod.s
Level 3
Level 3
Try in real time monitering tool .
You can setup alert in it
No we do not want to use RTMT for being notified about the alerts. Like i said we would like to know if there is a SNMP MIB which we could use to monitor the status of the SIP trunks.
You would not “use RTMT” for the alerts, the CM would be the entity that sends the alerts. You only use RTMT to define the alerts and whom to send it to.
Response Signature
Thanks Roger, that is what i meant, CM would generate the alerts and RTMT would be used to notify the same via email. But that is NOT what we are looking for.
Looking for MIBs which could be used to check the status of the SIP Trunks.
If you are looking to drill down into specific MIB / OID's, you probably will need to go through and look for which one meets your needs / goals.
Cisco has a nice SNMP object tool.
The top level CCM OID is 1.3.6.1.4.1.9.9.156 but there are hundreds of sub cantegories, including SIP calls.
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.156
