05-05-2013 06:55 AM - edited 03-19-2019 06:41 AM
Hi there,
I created a new mailbox store in the Unity connection 9.1.1 and the mailbox store status is ok.
Access was enabled too. I am able to add new user's mailbox on it.
However, when I tried to move some the mailbox from the default mailbox store I was moving failed message.
I was using a user with system admin role.
Did I miss anything? Thanks in advance!
Kevin
05-05-2013 08:48 AM
Hi Kevin,
Are you hitting any of these restrictions?
Moving Mailboxes Between Mailbox Stores in Cisco Unity
Connection 9.x
When moving mailboxes between mailbox stores, note the following:
When a mailbox is moved to another message store, the MWI status is retained.
When clustering is configured, you must sign in to
the server whose server status is primary to move
mailboxes.
Moving a mailbox fails if:
The administrator currently si
gned in to Cisco Unity Connection Administration is not
authorized to move a mailbox.
The source or target mailbox store is disabled be
cause, for example, the mailbox store is being
backed up.
The mailbox is disabled.
The user whose mailbox you are moving is a sy
stem user. System mailboxes cannot be moved
out of the default mailbox store, UnityMbxDb1
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/administration/guide/9xcucsag180.pdf
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
05-05-2013 11:44 AM
Thanks Rob for the answer.
However, I did check this in the system admin guide.
The mailbox I was moving doesn't belong to a system user. Both mailbox store are up and running.
I did use a system admin account to move the user mailbox from default mailbox store to a recenlty created one.
And I did it from the Unity connection publisher. But it still failed.
which system log should I check for more failure details? any other suggestion?
Kevin
