MPE 1.2 Flash Player Error
ckarwoski
I have version 10.0.12.36 of Adobe Flash player (the most current) but get the following error when I try to enter a meeting: Breeze Live requires Flash Player 6.0.65 or newer". Running MeetingPlace Express 1.2.1.23.
The data sheet says "Flash Player: 6.0.79 or later" should work. Other users with version 9 of the Flash Player have no problems.
Is version 10 of the Flash player not supported with this version of MeetingPlace Express?
DOUG DAVIDSON
Level 5
Level 5
I am not sure about Meeting Place Express 1.2, but I know that 2.x does not support Flash 10. It is a known bug CSCsv31317.
Here is the workaround for it:
The upcoming MeetingPlace Express 2.1 release will provide support for Flash player 10. In the meantime, the only workaround is to uninstall flash player 10 and reinstall the latest flash player 9.0.124 from the Adobe web site by following these steps:
1. Get the version of the FlashPlayer you already have installed on your client machine by following this technote; http://www.adobe.com/go/tn_15507
2. If you are running FlashPlayer 10 or higher continue with this procedure, otherwise you can stop here, you do *not* need to proceed.
3. Download the FlashPlayer 9 archive zip file that contains the Flash Player 9.0.124 among the other versions (the version 9.0.124 is located in the 9r124 subfolder): http://fpdownload.macromedia.com/get/flashplayer/installers/archive/fp9_archive.zip
4. Un-install the existing FlashPlayer by following this technote: http://www.adobe.com/go/tn_14157
5. Reboot the client machine Operating System
6. Install FlashPlayer 9.0.124 by running one of the following files depending on the Operating System and Browser you are using;
Windows 9x/ME/NT/2000/XP
- Internet Explorer: flashplayer9r124_winax.exe
- Netscape & Firefox: flashplayer9r124_win.exe
Mac OS PowerPC
- flashplayer9r124_mac.dmg
Mac OS Intel
- flashplayer9r124_ub_mac.dmg.zip
Solaris
- flashplayer9r124_solaris_x86.tar.bz2 (for Intel x86 based client machines)
- flashplayer9r124_solaris_sparc.tar.bz2 (for Sparc based client machines)
7. (optional) Check that you have FlashPlayer 9.0.124 installed by following this technote : http://www.adobe.com/go/tn_15507
HTH,
Doug
DOUG DAVIDSON
Level 5
Level 5
Mac OS PowerPC
Mac OS Intel
Solaris
HTH,
Doug
Perfect, thanks! Marked as resolved.
Shaun Bender
Level 4
Level 4
Also, if you checkout this field notice:
http://www-europe.cisco.com/en/US/ts/fn/631/fn63176.html
And contact TAC they'll send you a fix.
