Need help with sql query to generate report
rossporubski
Level 4
Level 4
Hi, I'd like to generate a report from Call Manager of all in use Forced Authorization Codes. Unfortunately I can't find any pre-defined query's in analyzer. Can anybody help? Thank you, I appreciate your help in advance.
lindborg
You'll probably want to ask this on the IP Telephony forum - that's where Call Manager users/support folks are.
Thanks for the heads up. Sorry bout that.
