Need some analogue lines, we use ISR 4000.
AhmadMA43005
we recently deployed  a IPT system and customer is asking for some analogue lines.can we make use of our ISR 4000 router for this. whats the maximum analogue lines supported.
3 Accepted Solutions
 you haven't mentioned the exact model. You can use isr 4K with High-Density Analog Voice cards.
go through below link
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-739991.html
Table 4.       4000 Series ISR platform compatibility
4000 Series platform
SM-X-8FXS/12FXO
SM-X-16FXS/2FXO
SM-X-24FXS/4FXO
SM-X-72FXS
4321
Not supported
Not supported
Not supported
Not supported
4331
Not supported
4351
Not supported
Not supported
Not supported
Not supported
4451
Response Signature
you need to order it separately.
RJ-21 Connector
Response Signature
5 Replies 5
SM-X-8FXS/12FXO
SM-X-16FXS/2FXO
SM-X-24FXS/4FXO
SM-X-72FXS
4321
Not supported
Not supported
Not supported
Not supported
4331
Not supported
4351
Not supported
Not supported
Not supported
Not supported
4451
Response Signature
so if we need 40 analogue lines we need to use 4351 ?
Hi Nithin,
cable to connect the lines comes along with the  module or do we need get it separately.
RJ-21 Connector
Response Signature
