11-24-2014 02:36 PM - edited 03-19-2019 08:52 AM
My plans are the following:
1. Acquired spare mcs 7825 server
2. Perform DRS restore from an up to date mcs cluster
3. Upgrade the 7825 to 8.x
4. Perform a DRS Backup
5. Restore the DRS back up onto the new pub?
*Step by step on getting the 6k built so that I can do step 5
11-24-2014 02:47 PM
There is nothing particular required for the 6K, the 6K is just a smaller OVA, but the actual installer, is exactly the same for any enterprise, 6K or 7K CUCM, even for the one you'll restore, it's the same thing.
Depending on the version you are going, and assuming this is not a 5K, you could use PCD to migrate in one step.
11-24-2014 03:23 PM
PCD? Not familiar with that...
11-24-2014 03:25 PM
Prime Collaboration Deployment, you can migrate from MCS to UCS in one step (caveat is you need to go to CUCM 10.0 or 10.5, and specific ESXi licensing), you can search more info on cisco.com if you're interested.
12-02-2014 06:49 AM
Jaime,
what you mean with "caveat...."? What I have understood is that you need a specif ESXi license to install PCD but you can install PCD in another server that meets requirements instead of installing it on BE6K, right? Any other caveat?
12-02-2014 07:52 AM
I meant caveat because the default ESXi licensing you get with 6K/7K does not allow you to use PCD, the servers that are going to be used need the APIs that are enabled by the FND license, or any of the VMware licenses.
12-02-2014 08:00 AM
Sorry Jaime. I need to clarify: do you mean I can not use PCD to upgrade CM to BE6k with Cisco UC Virt. Hypervisor 5.x?
Or do you mean that I can not install PCD in BE6k but I can install it on another server with the right VMpware licenses?
11-26-2014 08:25 AM
If you migrating from MCS to UCS this link might be useful
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/virtual/CUCM_BK_CF3D71B4_00_cucm_virtual_servers.html
DRS for 8.6
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/drs/8_6_1/drsag861.html
if you have an HP 7825 you will need a 16GB USB drive in order to upgrade
These release notes are based on following software versions:
Unified CM: 8.6.1.10000-43
If you are upgrading software on HP7825H3 or HP7828H3 hardware, ensure that you have a 16GB USB device available to migrate your data to the new system. For Unity Connection and Business Edition 5000, a 128GB external USB device is required.
11-26-2014 09:06 AM
so we are sitting on CM 7.1.3.30000-1, hardware 7825H3-IPC1, can't i just do a direct upgrade to 9.1?
11-26-2014 09:18 AM
7.1(3) to 9.1 is supported and your hardware is supported as well but you might need some extra ram
You mentioned 8.x that is why I thought you were going to 8.x, the external hard drive requirement is still needed when upgrading to 9.1
Hardware compatibility matrix:
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/prod_brochure0900aecd8062a4f9.html
11-26-2014 09:25 AM
yeah, I think it might be easier to go to 9.1, also I believe that the be6k will have 9.1 ova and ISOs...I am trying to take the pasth of least resistance.
11-26-2014 09:27 AM
I would agree!
