05-19-2015 03:40 AM - edited 03-19-2019 09:36 AM
I Need To Upgrade From Cisco Call Manager 8.5 to 10.x
What I need To Use & what is the steps to do this Upgrade ?
05-19-2015 03:58 AM
you need to go for Virtualization on CUCM 10.x, if not using .
You can either use PCD for migration
or refer the discussion https://supportforums.cisco.com/discussion/12449106/cucm-85-105-refresh-upgrade
You need to place the order through PUT to get the CUCM bootable/PCD.
regds,
aman
05-19-2015 05:54 AM
I Have a Physical server "IBM system x3650 m3" installed CUCM 8.5 On it
what i need to buy to make this upgrade to CUCM 10.x & from where i can buy , and what is the steps ?
05-19-2015 06:07 AM
You can opt for BE6000[if users are less than 1000] or BE7K for 1000+users.
For BE7K, UCS C 240 and UCS C220 for BE6K solution .Both the servers come pre-installed with applications.
You should get in touch with Cisco Partner for more details.
regds,
aman
05-19-2015 06:34 AM
thanks but can i upgrade without change the server ???
05-19-2015 06:55 AM
You need to change the Hardware and go for virtualization.
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unified_Communications_Manager_(CUCM)
regds,
aman
