Need To Upgrade From Cisco Call Manager 8.5 to 10.x
ahmdyosry00
I Need To Upgrade From Cisco Call Manager 8.5 to 10.x
What I need To Use & what is the steps to do this Upgrade ?
5 Replies 5
Aman Soi
you need to go for Virtualization  on CUCM 10.x, if not using .
You can either use PCD for migration
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/ucmapMigrate/10_5_1/CUCM_BK_M24251C0_00_migrate-procedure-for-cucm_1051/CUCM_BK_M24251C0_00_migrate-procedure-for-cucm_1051_chapter_00.html
or refer the discussion https://supportforums.cisco.com/discussion/12449106/cucm-85-105-refresh-upgrade
You need to place the order through PUT to get the CUCM bootable/PCD.
regds,
aman
I Have a Physical server "IBM system x3650 m3" installed CUCM 8.5 On it
what i need to buy to make this upgrade to CUCM 10.x & from where i can buy , and what is the steps ?
You can opt for BE6000[if users are less than 1000] or BE7K for 1000+users.
For BE7K, UCS C 240  and UCS C220 for BE6K solution .Both the servers come pre-installed with applications.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-7000/data-sheet-c78-730649.html
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/data_sheet_c78-717454.html?cachemode=refresh
You should get in touch with Cisco Partner for more details.
 regds,
aman
thanks but can i upgrade without change the server ???
You need to change the Hardware and go for virtualization.
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unified_Communications_Manager_(CUCM)
regds,
aman
