New 4.0.5 Unity Build with Failover
admin_2
Level 3
Level 3
The Unity build went well, all appears to be working fine. However, I have one problem: when I start the web/sa on the primary server, click on anything (subscribers), web/sa stops responding. I have the same issue on the secondary server.
Any help would be appreciated!
Tommer Catlin
Is this from your workstation or at the server?
most likely, it's something strange with the Java settings on your machine, or you have security settings in IE not working. SA does not seem to work that well FireFox either.... so stick to IE.
Also, check your permissions. If UnityAdmin is not working, try logging in as Administrator.
I would try off the server console first though
Thanks for taking the time to respond. In the meantime I resolved the issue.
What was it? Same issue here with all things mentioned above checked and double checked.
