		03-17-2013
		07:34 AM
 - last edited on
		03-25-2019
		09:49 PM
 by
			ciscomoderator
Hello All,
Please assist the given below points regarding New and advance features.
1> Comparison of New and advance features of Unity connection v9.1, it is simple that features comparison guide between unity connection v7.1 and unity connection v9.1 ..
2> What could be the major difference between unity connection v7.1 and v9.1?
I am realy thankfull to them who actualy give any guidelines or post any relating links on it.
Solved! Go to Solution.
03-19-2013 05:34 AM
Hi Amit,
You are most welcome
I have tried over the years to capture these notes in the
attached doc. Thanks to Gordon for his contributions;
It's not comprehensive but it should have the info you require.
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
03-17-2013 08:01 AM
Hi Amit,
You need to check the
New Functionality
8.0
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/801cucrn.html#wp403185
8.5
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/851cucrn.html#wp1080782
8.6
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/861cucrn.html#wp1273219
9.0
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/release/notes/901cucrn.html#wp1509875
9.1
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/release/notes/911cucrn.html#wp1509875
Cheers!
Rob
- Stones
03-19-2013 05:12 AM
Hi Rob,
Thanks for your quick reply,
I have one more concern regarding CUCM, Can you please assist the same?
1>  Comparison of New and advance features of Cisco Unified Communication Manager v9.1, it is simple that features comparison guide between Cisco Unified Communication Manager v7.1 and Cisco Unified Communication Manager v9.1 ..
2> What could be the major difference between Cisco Unified Communication Manager v7.1 and v9.1?
I am realy thankfull to you for support and guidelines or post any relating links on it.
03-19-2013 05:34 AM
Hi Amit,
Cheers!
Rob
- Stones
