05-07-2008 04:39 AM - edited 03-18-2019 08:54 PM
Hi all,
when I access the Media Convergence server through browser,I can access its "OS Administration" with the configured username and password,It does not take the username and password for the"CM Administration,Serviceability & Disaster Recovery system" options
Anybody has the solution !
Sudeesh
05-07-2008 06:34 AM
are you using the username / pwd you created during the install or another user to which you granted access??
are the DRF services running??
javalenc
if this helps, please rate
05-07-2008 06:38 AM
Hi javalenc,
Yes , I am using the same username/password I created during Installation
DRF services are not running
Sudeesh
05-07-2008 06:41 AM
try starting them and then try again
javalenc
