01-23-2015 06:41 AM - edited 03-19-2019 09:04 AM
Hi Everyone
I had an issue with a site that I have in Orange County California, the time on all the devices was ahead by 15mins.So I restarted the NTP service and it fixed the issue but when I use the Utils NTP Status command I see that it says that the service is unsynchronised and that the server is re-starting. Should I worry about this since my time is correct now or does it matter and I've attached a pic of the screen and thanks in advance and everyone have a great weekend.
Eric
Solved! Go to Solution.
01-23-2015 07:45 AM
I did not understand what u are trying to say.
You need to get the NTP correct since I have seen issues where backup could not be taken due to this issue.
regds,
aman
01-23-2015 07:28 AM
the snapshot shows NTP is unsynchronised.
you need to get this rectified.
regds,
aman
01-23-2015 07:41 AM
Aman
Could the time potentially end up being off again, I thought that something was still wrong.
01-23-2015 07:45 AM
regds,
aman
01-23-2015 07:47 AM
Thanks Aman
I will open up a case with TAC and work on this beuase I don't want the backups to be effected.
Eric
01-23-2015 07:52 AM
Hi Eric,
there is nothing to panic.
This is the one issue which I faced so thought of sharing.
Do check the timings[router or switch /Linux server] on device where NTP is configured ?
regds,
aman
01-23-2015 07:55 AM
Thanks Aman
