Outgoing Translation Pattern for Dial-Peer
scooter817
Level 2
Level 2
I wanted to know can someone tell me how would I create an outgoing translation pattern for a SIP dial-peer. We just moved one of our sites to SIP yesterday and my manager wants to know how can I create a sip dial-peer with a destination pattern that will begin with 9 but will strip the 9 before it's sent out. I'm placing the current dial peer in the this post and thanks in advance for your help and I look forward to your replies.
 description 10 Digit Calls to ITSP
 preference 1
 destination-pattern ^[2-9]..[2-9]......$
 session protocol sipv2
 session target sip-server
 session transport udp
 voice-class codec 1
 voice-class sip early-offer forced
 voice-class sip profiles 1
 dtmf-relay rtp-nte h245-alphanumeric
 fax-relay ecm disable
 fax-relay sg3-to-g3
 fax rate 14400
 fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 1 fallback pass-through g711ulaw
 ip qos dscp cs3 signaling
 no vad
Translation rules apply to both, post and voip DPs.
java
if this helps, please rate
Jaime Valencia
There's plenty of documentation on translation rules on cisco.com, and they have a lot of examples on how to use them, have you reviewed any of it???
java
Hi Jaime
I did that and everything I find keeps talking about POTS lines not a VoIP dial-peer.
java
