PA/GA system over ISR to CUCM
Oblivion_Tech
Hi everyone,
I'll try to spare you all for details and hope these few information would be enough to get to the solution.
We've replaced an old Panasonic phone system with a CUCM and now we are having issues to get our PA/GA system integrated into CUCM. Old Panasonic system had PA/GA connected to the MCSLC board (SLT) and it worked fine.
We moved PA/GA from Panasonic system to the FXS board (ISR 4351) and when assigned number is called from Cisco IP phone (CUCM), PA/GA system gets a signal for a second but doesn't hold (latching missing).
On Panasonic system there was a "Data mode" switched ON only for PA/GA extensions while for the rest of extension it was OFF (if that information helps)
Appreciate your help,
Thank you
What is "PA/GA"? Is that paging? Music on hold? It isn't possible to suggest anything without knowing more about the connection.
