04-07-2015 08:22 AM - edited 03-19-2019 09:26 AM
Party Entrance Tone not working on CUCM 10.5(1.10000.7) . This is an intermitent issue for Meet Me conference.
++On the CUCM Service Parameter Party Entrance Tone has is TRUE .
++On Directory number Party Entrance Tone is ON . However the Party entrance tone (Beep tone) not coming when Meet Me conference going on .
Gateway 3945 with IOS Version 15.3(3)M5, RELEASE SOFTWARE (fc3).
The conference Configureation as below.
sccp local GigabitEthernet0/0
sccp ccm 172.20.0.152 identifier 1 priority 1 version 7.0
sccp ccm 172.20.0.153 identifier 2 priority 2 version 7.0
sccp ccm 172.22.0.110 identifier 3 priority 3 version 7.0
sccp ccm 172.22.0.111 identifier 4 priority 4 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate ccm 4 priority 4
associate profile 2 register ASB-DR-GW04CFB
associate profile 1 register ASB-DR-GW04XCO
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 60
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum conference-participants 32
maximum sessions 12
Can any one tell me how the party entrance tone happening when a confernce session open.Is it generated from the hardware Confernce resource which configured on the gateway while mixing the RTP streams ? Is there anything to do with CUCM or any service in CUCM to generate the Party entrance tone ?
Solved! Go to Solution.
04-09-2015 04:33 AM
It looks like the following bug
https://tools.cisco.com/bugsearch/bug/CSCup27560/?referring_site=bugquickviewredir
Symptom:
- MeetMe party entrance tones stop getting played to participants when they join/leave
- The issue will go away for a few weeks if the CCM service is restarted, but then will come back.
- When the issue comes back, it fails 100% of the time.
Conditions:
This problem would occur when we have user having a call from user in different node initiate transfer and also initiate MeetMe and dial user in different node. When transfer completes, we will have a leak in current node MeetMe. This issue should have been there in all CCM versions.
Workaround:
Restarting the CCM service will correct the problem temporarily.
You can either try the workaround or upgrade to one of the fixed versions.
Manish
04-09-2015 04:33 AM
Symptom:
Conditions:
Workaround:
Manish
04-09-2015 04:36 AM
Additionally, for the CUCM to be able to play the party entrance tone: Ensure that you turned the privacy feature off for the devices and ensure that the controlling device for the multiparty call has a built-in bridge. In addition, either configure the Party Entrance Tone service parameter, which supports the Cisco CallManager service and the entire cluster, or configure the Party Entrance Tone setting per directory number in the Directory Number Configuration window (Call Routing > Directory Number).
Manish
04-09-2015 11:55 PM
Thanks for your valuable comment.
I know that we are hitting the defect CSCup27560 . Checking the stable version of CUCM (most bug free one). If you have any suggestion most welcome.
04-10-2015 12:53 AM
My suggestion would be to upgrade to 10.5(2)SU1 which can be downloaded from here
https://software.cisco.com/download/release.html?mdfid=285963825&flowid=50402&softwareid=282074295&release=10.5%282%29SU1&relind=AVAILABLE&rellifecycle=&reltype=latest
Read Me file
http://www.cisco.com/web/software/282074295/121471/cucm-readme-1052su1.pdf
Manish
