PCD
Marxus Johnson
Is PCD loaded on a new BE6K servers? I don't see it in the Bill Of Materials??
Jaime Valencia
Not AFAIK, that's always an optional product you need to install if required.
java
if this helps, please rate
OK that's what I thought!!! Thanks!!
Laith Ibrahim
the bad thing here that the VMware license that comes with cisco server isn't supported by PCD
