12-26-2019 06:14 AM
we have a Unity Connection and Communication Manager, both version 11.5.
A user has activated the busy greeting, has recorded a personal busy greeting, which is enabled, but still when she is busy, the standard busy greeting is played.
If I disable the busy greeting, the standard message is heard. If I enable the busy greeting, the standard busy greeting is heard in stead of the recorded busy greeting.
Any idea what's the issue here?
Kind regards
Solved! Go to Solution.
01-06-2020 06:51 AM
I have recorded a new personal busy greeting and now it works. Apparently there was something wrong with the original greeting.
Thanks for the help.
12-26-2019 09:05 AM
12-26-2019 09:25 AM
Thanks for the reply.
I know the difference between the Alternate greeting and the Busy greeting.
The issue is that the personal Busy greeting is not played when the user is in another conversation. The default Busy greeting is played instead.
01-02-2020 09:35 AM - edited 01-02-2020 09:36 AM
The Busy Trigger value set for the directory number decides how to route the caller. Here are three different scenarios:
1. User-A Busy Trigger set to 1. If User-A is already on a call with User-B, and if User-C calls User-A, then User-C will immediately hear Busy Greeting.
2. User-A Busy Trigger set to 2. If User-A is already on a call with User-B, and User-C calls User-A. If User-A do not answer the call, then User-C will hear Standard Greeting.
3. User-A Busy Trigger set to 2. If User-A is already on a call with User-B, and User-C calls User-A. If User-A answer the call, then next caller will immediately hear Busy Greeting.
01-02-2020 02:49 PM
Yes, I know al that.
You don't seem to understand my problem.
There is a system default Busy greeting, but you can also record your own personal Busy greeting.
When a user is on another line, the system default Busy greeting is played instead of the personal Busy greeting.
01-03-2020 08:45 AM
Are you using SIP or SCCP integration between CUCM and Unity Connection?
For similar issue, there are multiple software bugs related to SIP integration. These software bugs are reported for Unity Connection release 10.5. May be you can open a Cisco TAC case to get more details:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq90525
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuv06005
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw55559
01-03-2020 09:21 AM
Thanks for the reply. We are using SIP between CUCM and Unity Connection. I will check the bugs reports to see if this is the cause of my problem.
01-06-2020 12:32 AM
I have checked the bugs you mentioned, but this is not the same problem that I am encountering.
My problem is not that I don't get a busy greeting. I get a busy greeting when the user is on another line. So far the system works fine.
But the problem is that she recorded a personal busy greeting, but we still hear the system busy greeting, not the personal busy greeting.
01-06-2020 05:08 AM
Is this issue only for one particular user or many users? Have you tried similar scenario for other users. If the problem still persists then I would recommend to open a Cisco TAC case.
01-06-2020 06:51 AM
01-08-2020 07:30 AM
Do you have multiple locales or languages installed? I've seen issues where the personalised greeting had been recorded in say US English but the configuration was such that a caller expected to hear UK English.
