03-24-2011 07:30 AM - edited 03-19-2019 02:37 AM
I have Integration between CUCM and CUPS.
I have downloaded the Personal Cmmunicator and get to work but i ahave the below issue:
CUPC is not registering with the CUPS for some reason the CUPC keeps trying to connect/register with the CUPS.
Attached is a snap shot of the Personal Communicator Health Check.
Any help will be highly appreciated.
03-24-2011 07:55 AM
Hi Karam,
From the snapshot I can see that there are at least two missing configs:
1) Presence is not connected: This is due because the Proxy domain was not set
2) LDAP server is not configured.
I would advise to follow the step by step guide from the following link:
HTH,
Nick
03-26-2011 11:19 AM
I have done all the steps before with a document that i found on Cisco Website and i conformed the same with the document that you have sent me.
For some odd reason i have an Alert (As per the attached) on the Cisco Unified Presence Administration Page, but when I run the System Troubleshooter under SIP Proxy section the outcome is successful. Any more ideas on this will be highly appreciated.
I have attached a full snap shot of the System Troubleshooter for another 2 errors that i have also.
Thank you and waiting for a response
