phone not resrting and confguration changes are not applying
bluesea2010
Level 5
Level 5
When the phones are registered in subscriber , configuration restart and not applying
cucm 11.5
PLease help
17 Replies 17
From what I know using a Windows NTP server is not supported. The reason being is that Microsoft does not follow the standard for the NTP protocol for their implementation of NTP server.
Response Signature
Did you first removed the old one?
utils ntp server delete
and select which you want to remove.
Ntp service should automatically restrart after server deletion.
Carlo
Please rate all helpful posts "The more you help the more you learn"
yes I did this , but after restarting  ntp service still showing old ntp server
