Phone Proxy for Cisco Mobile 8 iPhone
limbadiya
We have ASA 5505 configured with phone proxy and we use ip communicator to connect to the call manager from outside. Is it possible to use iPhone with phone proxy, I tried to enter the external tftp ip address but it's not working. Any idea?
benjaminwatt
Level 5
Level 5
It's not possible with current versions, your only option for using Cisco Mobile 8.0/8.1 for iPhone when away from your network is to first connect via a VPN. The phone proxy option is out for now, but fingers crossed that it will appear in the future.
benjaminwatt
Level 5
Level 5
I hope we have that, I wish there is way to use iPhone without VPN from outside.
Dear, i was just exploring and found your page, i am going to setup phone proxy using ASA5510 and Callmanager 6.0, i am unable to set up ip communicator to download LSC can u help me in this regards thanks,
Bilal
Brother, I have no idea on Phone proxy, But I have this config from ASA 5505, they have ASA phone proxy already setup, may be you can find something out of this.
I have change the value for security reason,
"tls-proxy ASA-tls-proxy
server trust-point _internal_PP_ctl_phoneproxy_file
ctl-file ctl_phoneproxy_file
record-entry capf trustpoint capf_trustpoint_2 address "external_ip"
record-entry cucm-tftp trustpoint phoneproxy_trustpoint address "external_ip"
no shutdown
media-termination my_mta
address 172.16.108.2 interface inside
address "external_ip" interface OUTSIDE
phone-proxy ASA-phone-proxy
tftp-server address 172.16.110.2 interface inside
no disable service-settings
proxy-server address 172.16.110.2 interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server "external_ip" prefer
webvpn
enable OUTSIDE
svc image disk0:/anyconnect-win-2.3.0254-k9.pkg 1
svc enable
tunnel-group-list enable
group-policy SSL-VPN-Group-Policy-1 internal
group-policy SSL-VPN-Group-Policy-1 attributes
dns-server value 172.16.8.8 172.16.8.14
vpn-idle-timeout none
vpn-tunnel-protocol svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value BC-Networks
default-domain value bakercompanies.com
webvpn
  svc ask enable default svc timeout 15
group-policy pcf-vpn-policy internal
group-policy pcf-vpn-policy attributes
class-map sec_sip
match port tcp eq 5061
class-map sec_sccp
match port tcp eq 2443
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect dns preset_dns_map"
