11-07-2012 07:37 AM - edited 03-19-2019 05:50 AM
I have the following problem with VMware ESX .... UC I moved from one network to another and now I can not access the CCM 8.6 assume it's for the next shot ...
I welcome your comments please
11-07-2012 09:57 AM
Hi Juan,
Could please explain for me each step that you did before this happens.
Did you change the IP Address of the server?
Best regards,
Daniel
11-07-2012 10:12 AM
If you just changed the network under the VM in ESXi, are you sure there's connectivity??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-07-2012 02:08 PM
thanks for the answers ... Dsobrinho .. I perform a pre-configuration elsewhere and when you take the recipient gave me this error ... if I connect directly to UCS and use an ip within the network segment I can access the CCM, but when I connect to the network to access any place I fail to ping.
---Jaime does not change the IP address, I move the entire team from one place to another and apparently tries to find the MAC address of my previous GW
