plz help whit this problem
I have the following problem with VMware ESX .... UC I moved from one network to another and now I can not access the CCM 8.6 assume it's for the next shot ...
I welcome your comments please
dsobrinho
Level 9
Level 9
Hi Juan,
Could please explain for me each step that you did before this happens.
Did you change the IP Address of the server?
Best regards,
Daniel
Daniel Sobrinho
Jaime Valencia
If you just changed the network under the VM in ESXi, are you sure there's connectivity??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
thanks for the answers ... Dsobrinho .. I perform a pre-configuration elsewhere and when you take the recipient gave me this error ... if I connect directly to UCS and use an ip within the network segment I can access the CCM, but when I connect to the network to access any place I fail to ping.
---Jaime does not change the IP address, I move the entire team from one place to another and apparently tries to find the MAC address of my previous GW
