Port Usage Analyzer
jforcum
When I run Port Usage Analyzer (1.0 Build 61) on Unity 4.04 SR1, I only get data back for 57 ports; whereas, Unity has 72 ports. I want to see how many ports are busy with MWI.
Is this a bug in PUA? Why does it not give me data for all 72 ports. The summary info also truncates at 57 ports. Is this fixed in a later release?
lindborg
No, it's been tested with 72 ports in house - I suspect you're not getting valid activity that's being logged on anything above port 57 for whatever reason - you can check the AvCSMgrxxx.log files manually to verify this.
