AD Schema extension for Unity
JimSJ
Level 4
Level 4
I am trying to verify that the AD schema extension for Unity was run successfully on a 4.0(4) system. It was installed by someone else and he mentioned that he wasn't sure if the schema was extended properly. Is there a good way to check this, like with Exchange extensions where viewing a user in AD and seeing additional tabs would indicate the schema is extended?
Thanks!
Hin Lee
Find out what account was used to run the AdSchemaSetup.exe. On the desktop of that account, there is a folder called LDIF LOGS. If the util failed, the information will be in the log.
