Prioritizing calls in different queues
cilindsey
We have several different queues and one of them is extremely busy constantly, is there a way to prioritize a call coming in from one of the other queues even though the other calls have been waiting longer?  I saw another post and I placed a "Set Priority" step at the beginning of the "queued" option of the "Select Resource" step for each CSQ.  I then called in on the line that has a priority 2 and called in on the line that has a priority 1 after that and went into available on the agent desktop and I still received the call that was waiting the longest first even though it was a priority 2.   I am stumped and I would appreciate the help.  We have UCCX 5.0.
Brad Magnani
Hi Cindy,
Thanks for your posting.  I believe your post may be best suited for the Contact Center forum here: https://supportforums.cisco.com/community/netpro/collaboration-voice-video/contact-center?view=overview  I would recommend posing your question there instead so you can get the help you're looking for.
Brad
