07-09-2013 11:19 PM - edited 03-19-2019 06:58 AM
I am trying to register our 8961 Cisco IP Phone to register to the CUCM 7.1.3 but it doesn't seem to appear in the list of the phones supported. Upon further research, we found out that it is actually a SIP Phone. We tried registering it as a SIP Phone, however we cannot find any user/password field in the phone itself.
I hope anyone can help out.
07-10-2013 01:45 AM
Which exact version of CUCM are you running as this phone is supported on 7.1(3a)SU1 =7.1.3.21900-4 and newer:
HTH,
Chris
07-10-2013 02:14 AM
CUCM 7.1.3.30000-1
Roi
07-10-2013 02:20 AM
You may need to download latest device pack for version 7.1.3:
cmterm-devicepack7.1.3.33031-1.cop.sgn
HTH, please rate all useful posts!
Chris
07-10-2013 02:33 AM
Will this update affect existing ATA 186 in our network?
Thanks Sir!
Roi
07-10-2013 03:05 AM
It may change the firmware version, if you do not want to update any firmware versions you will need to take a note of your current firmware versions under device defaults and then change it back after installing the device pack.
HTH,
Chris
