Problem with Conference Bridge Secure - CUCM -ISR 2901
reyesclaudio
I have a problem to configure a Conference Bridge Secure, the router has a self signed certifcate and the CUCM is signed by ca. So I uploaded the certificates between them, but the conference does not registered.
These is the logs from router:
Dec 17 00:13:19: sccp_tls_init_and_config_context ccm trustpoint CUCM2 length 11
Dec 17 00:13:19: sccp_client_do_tls_handshake
Dec 17 00:13:20: SSL Handshake Error -6983
Dec 17 00:13:21: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
Dec 17 00:13:21: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
Dec 17 00:13:21: SCCP(profile 997)send KeepAliveMessage to ccm identifier 3
Dec 17 00:13:21: sccp_transmit_msg: sending on socket 1
Dec 17 00:13:21: sccpapp_process_socket_events: appl_type 3, soc_fd 1, soc 1, swb_soc -1
Dec 17 00:13:21: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 3, eve 4, state 6
Dec 17 00:13:21: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 1
Dec 17 00:13:21: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 1
Dec 17 00:13:21: sccp_get_control_message: sccp cntl msg rcvd, prof_id 997, appl_type 3, msg_len 4
Dec 17 00:13:21: sccp_spi_ha_is_not_ready_to_handle_new_msg: sccp_spi_ha_is_not_ready_to_handle_new_msg
Dec 17 00:13:21: sccp_parse_control_msg: msg_ptr 40005688, msg_len 4, msg_id 256
Dec 17 00:13:21: sccp_parse_control_msg: glob_ccm->version 9
Dec 17 00:13:21: SCCP(profile 997)rcvd KeepAliveAckMessage from ccm identifier 3
Dec 17 00:13:21: SSL Handshake Error -6983
Dec 17 00:13:22: SSL Handshake Error -6992 device
Dec 17 00:13:22: sccp_tls_client_instance: TLS handshake failed for profile 997
Dec 17 00:13:22: sccp_tls_client_instance :: soc 1, swb_soc -1, tls_sock 0
Dec 17 00:13:22: sccp_tls_client_instance socket inheritance failed for appl 21026A20
Dec 17 00:13:22: sccp_tls_client_instance sccp_connection_type: 1
Dec 17 00:13:22: sccp_tls_client_instance: event 15 enqueued for prof_id 997, appl_type 3 reg_name
Dec 17 00:13:22: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero for CCAPI event
Dec 17 00:13:22: sccpapp_process_sys_events: sys_eve 15, xlated_eve 18
Dec 17 00:13:22: sccpapp_process_sys_events: swb_sys_eve 15, xlated_eve 18
Dec 17 00:13:22: sccpapp_process_sys_events: sys_eve 15, for prof_id 997, appl_type 3
Dec 17 00:13:22: sccp_tls_common_process_teardown_complete
Dec 17 00:13:22: sccp_initiate_swb_interval_timer: Start SWB retry(interval) timer for appl_type 3un all
Any idea that what happend?
What did you do to solve your problem?
