Problem with fax ATA 191
akram.root
Level 4
Level 4
Hello all,
I need your help please,
I hava a ATA 191 registered with cucm 11.5 and configured with fax mode : T.38 relay.
The problem that i have when i call this ata i can't receive fax carrier , just i hear the ring back and the call dropped .with termination cause code (18) no user responding
What that is mean ?
Could you help me please to solve this problem.
Thanks in advance
Best regards
akram.root
Level 4
Level 4
Any answer please
Best regards
Are you sure that its t.38 Fax protocol is used by your ISP.
When you connect an analogue  phone on ATA does the call lands ? Have you tried that ?
Does your fax machine set to auto answer the calls ? If i am not wrong there is some sort of settings on FAX machines to..
Response Signature
Thank you @ Nithin Eluvathingal for your reply and your your support always,
The service ISP told me that t.38 Fax protocol is is well applied.
When you connect an analogue phone on ATA does the call lands ? I did not do this test, I will ask to do that .
Does your fax machine set to auto answer the calls ? i don't know , i will ask my customer for that
Thank you
Best regards
