Process ciscocm.preUpgradeCheck-00024.cop blocks the installation subsystem CUCM
Sergey 1907
I have a small gap. During execution ciscocm.preUpgradeCheck-00024.cop, SecureCRT lost connection to the server. I solve this at night by restoring the entire VM from the backup. But maybe you know less radical ways
P.S. This is some kind of vicious circle, a penny file blocks the installation subsystem completely. Reboot doesn't help
admin:show status
Host Name : spbo-ucm-1 (short name)
Date : Tue Mar 30, 2021 06:50:03
Time Zone : GMT-03:00 (Etc/GMT+3)
Locale : en_US.UTF-8
Product Ver : 12.5.1.12900-115 Unrestricted
Unified OS Version : 7.0.0.0-4
admin:show network eth0
DNS
Primary : 172.19.6.11 Secondary : 172.19.6.12
Options : timeout:5 attempts:2
Domain : mydomain.com (domain name)
Gateway : 172.19.2.1 on Ethernet 0
Welcome to the Platform Command Line Interface
VMware Installation:
2 vCPU: Intel(R) Xeon(R) Gold 5217 CPU @ 3.00GHz
Disk 1: 110GB, Partitions aligned
8192 Mbytes RAM
admin:utils system upgrade initiate
Warning: Do not close this window without first canceling the upgrade.
Warning: Before upgrading the cluster Cisco recommends installing the latest Upgrade Readiness COP file. Refer to the Upgrade Guide on cisco.com for details.
An upgrade is already in progress.
Upgrade status: Installing
Upgrade file: ciscocm.preUpgradeCheck-00024.cop
Upgrade log: install_log_2021-03-30.05.07.46.log
admin:utils system upgrade cancel
Canceling the upgrade. Please wait...
Installation of a Cisco Options Package (COP) cannot be canceled. WTF??? Why??? it is simple script
admin:
admin:file view install install_log_2021-03-30.05.07.46.log
- Test result : PASS, Recommendation :
*) 12.5
Passed: You have 37 GB of required 27 GB common partition space required for L2 upgrade to 12.5.
03/30/2021 05:08:47 ++
03/30/2021:05:08:47 /common/download/TestManager/tests/TestServiceStatus.py:219 - INFO - Extracting System Services from CLI Output when Service Manager running
03/30/2021:05:08:47 /common/download/TestManager/tests/TestServiceStatus.py:97 - INFO - Critical (Network) services which are down are: {'Cisco Certificate Enrollment Service': 'STOPPED'}
03/30/2021:05:08:47 /common/download/TestManager/tests/TestServiceStatus.py:45 - INFO - Saving Pre Upgrade Data for 'utils service list'
end of the file reached (point of disconnection with the server)
options: q=quit, n=next, p=prev, b=begin, e=end (lines 401 - 404 of 404) :
6 Replies 6
I would say that the recommendation for you would be to reach out to TAC to get help to resolve the locked file from root access instead of restoring the VM from DRS.
Response Signature
Hi Roger
Not DRS )), from Veeam VM backup, virtual machine recovery takes no more than 15 minutes, and communication with TAC can take half your life
Bug ID  CSCvq22312 is similar  but not the same case as yours and not the same version.
I would recommend to open a TAC, if its critical raise the case  Priority.
Response Signature
Hi Nithin!
Yes, not the same case, not  CSCvq22312
admin:show status
DNS
How do Veem make the backup of the VM?
I do acknowledge that it could take a bit of time with TAC at time, but for the most it’s not my experience. They do have the customers best in mind and wants to be as helpful as possible.
Response Signature
Im using Veeam Backup & Replication 10 (Enterprise Plus license) with multinodes and multi datastories VMware vSphere 6.7 and daily back up the entire virtual machines (CUCM Pub and SUB, IM&P PUB and SUB, UCCX, Expressway-C and E, Cisco Meeting Server with Cisco Meeting Management, CUC) to HDD Library
