PSTN->Unity Connection AA->Extension as on-net calls
Eduardo Cruz
Hello
Is there a way to set all calls from the Auto Attendant in Cisco Unity Connection to be off-net and not on-net calls.
I would like to use the CallManager "Forward no answer external" but all my external calls go through the Unity Connection AA and become on-net.
Thanks.
Jaime Valencia
Assuming you're SIP integrated, you could change the settings there, that's the only way I can think of, and I'm not sure it will work, if you're SCCP integrated, there is no way to do it.
java
if this helps, please rate
Jaime Valencia
java
We are SCCP integrated. I will try to change to SIP.
Thank you
