question for Single Number Reach - CUCM 11.5
cooperma31
so we have 10 digit extensions, that match our DIDs.  we have a person who only wants incoming calls that dial the DID (outside the organization) to pass through to his single number reach configuration.  Is this doable?
7 Replies 7
Jaime Valencia
You can try with an ACL that matches only your internal dial plan
java
if this helps, please rate
how would i do this in call manager?
Create the allow ACL that adjusts to your dial plan, then apply to that remote destination.
java
i guess i am failing to understand how this would work.  i see the ACL options, and i am looking at it, but i guess i dont understand how this is supposed to work?
edit -  you mean the feature - "call routing -> class of control -> Access List right?
Go the remote destination page, click on the one you're interested in, and see at the bottom of that page.
java
i see what you are talking about.  so if i want to block 4 digit internal calls to the extension on SNR.  i tried a block xxxx statement, and that didnt work.  any thoughts on what kind of statement that would be?
Again, that will depend entirely on your dial plan, use help -> this page while on the acl config page for examples.
java
