01-18-2018 12:20 PM - edited 03-19-2019 01:04 PM
so we have 10 digit extensions, that match our DIDs. we have a person who only wants incoming calls that dial the DID (outside the organization) to pass through to his single number reach configuration. Is this doable?
01-18-2018 02:40 PM
You can try with an ACL that matches only your internal dial plan
01-19-2018 06:46 AM
how would i do this in call manager?
01-19-2018 07:42 AM
Create the allow ACL that adjusts to your dial plan, then apply to that remote destination.
01-19-2018 07:51 AM - edited 01-19-2018 07:53 AM
i guess i am failing to understand how this would work. i see the ACL options, and i am looking at it, but i guess i dont understand how this is supposed to work?
edit - you mean the feature - "call routing -> class of control -> Access List right?
01-19-2018 07:54 AM
Go the remote destination page, click on the one you're interested in, and see at the bottom of that page.
01-19-2018 08:02 AM
i see what you are talking about. so if i want to block 4 digit internal calls to the extension on SNR. i tried a block xxxx statement, and that didnt work. any thoughts on what kind of statement that would be?
01-19-2018 08:11 AM
Again, that will depend entirely on your dial plan, use help -> this page while on the acl config page for examples.
