11-09-2016 06:53 PM - edited 03-19-2019 11:48 AM
Hi All,
I have just reinstalled vSphere on BE6000H, the installation was successful and added the pre-installed appliances but the ESXi screen is not showing the initial message it used to show re: pre-installed applications.
I am just wondering if there is a setting on the vSphere to show the message?
Thanks in Advance,
B
11-28-2016 09:04 AM
Not sure if that is going to be possible, but your appliance will be on the data store as you indicated.
What you need to look out for is because you reinstalled the vmWare license will be in eval mode you will have to apply the license key.
If you did not take a note of it before the reinstall its usually shipped together with the server.
11-29-2016 12:55 PM
So it's best if you save or download the file from Cisco. The only challenge I am having now is to figure out if there are any default kernel /
Cisco definitely doesn't make it easy to find those settings.
B
11-29-2016 10:24 AM
Moving this discussion to the Unified Comm Forum.
