Replacing Unity Connection Subscriber
mumbles202
Level 5
Level 5
If I'm replacing a Unity Subscriber do I need to reboot the Publisher after I delete the subscriber from the admin page?  I followed the instructions to remove a sub and I was able to add the server in the admin page, but when I try to run the install for the subscriber it keeps failing stating that the publisher isn't the first node in the cluster.  I've confirmed hostname/ip address and the security password should be correct as well based on testing (setup a test vm and pointed to the backup location and verified I could see the backup from the restore pane after confirming the security cluster matched what I had documented).unity, UC Applications, Other Unified Communications
*** Got this sorted by changing the security password and rebooting the publisher.  Might not have been needed but it proceeded.
0 Replies 0
